[GRASSLIST:4030] Re: CELL Driver won't start (5.0.0pre3)
Eric G. Miller egm2 at jps.net
Fri Jul 5 01:53:24 EDT 2002
On Thu, Jul 04, 2002 at 09:52:20PM -0700, cheg01 at attbi.com wrote:
> I'm trying to use the CELL driver to save d.his images. I set the
> environment variables for GRASS_HEIGHT=4000 and GRASS_WIDTH=6000. When I
> run "d.mon start=CELL" I get the following error:
> Segmentation Fault - core dumped
> No socket to connect to for monitor <CELL>.
> Problem delecting CELL. Will try once more
> The CELL driver is present in $GISBASE/driver and I ran
> $GISBASE/dev/create_fifos.sh. Any suggestions?
If you have gdb installed (the GNU debugger) can you load the
core file and get a backtrace -- this will tell where the
CELL driver error occurred.  Send the backtrace as a follow-up.
Eric G. Miller <egm2 at jps.net>
