[GRASSLIST:4091] Re: dynamic modeling advice? II
Radim Blazek
blazek at itc.it
Thu Jul 18 04:02:50 EDT 2002
On Wednesday 17 July 2002 07:01 pm, Alex Thorn wrote:
> I'm still pretty new to programming and GIS in
> general, as well as GRASS specifically, so pleas
> forgive me if I have trouble understanding exactly
> what you mean. I am currently using GRASS43 for my
> project. Is the concensus that it would be worthwhile
> for me to switch to GRASS50 at minimum?
I think so, most users use 5.0, see:
http://grass.itc.it/announces/grass_questionnaire_2002_synthesis.html
> The idea of fast vector manipulation is interesting to
> me, but I'm wondering how easy it would be to export
> the results in an ascii format, so that it could be
> read by the C program that is currently the core of
> my model.
Why should be ascii export problem? But it isn't necessary.
If you want to use GRASS only as GIS part of your model
(and do not need GIS-independent intermediate format),
you can write it as GRASS module and read/write directly
GRASS files.
> > (i run test now: 8s/340000 lines; i think, it was
> > about 3h in grass50)
> What were you testing? Are these lines of a GRASS
> script?
No, it is number of lines in vector file and time of v.build
(v.support).
> This looks like C code. I'm a bit confused as to
> how this would fit together with GRASS.
GRASS is written in C, so it fit together very well.
> Would this
> code need to be added to the actual GRASS source code?
This code may be your custom GRASS module. For compilation
you need GRASS sources.
> I haven't actually figured out how to compile GRASS
> from the source, and have been using precompiled
> binaries. Should I try to work on learning how to
> compile from source, or is that more trouble than it
> is worth (I note that I would also have to compile
> from source if I was going to use GRASS51 at all: the
> binaries are evidently not yet available).
Compilation should be easy (./configure, make) but you need to learn
how to write grass module - easy way is to copy and modify existing
module.
Radim
