[GRASSLIST:4093] r.in.gdal question
Kevin Slover kevin.slover at noaa.gov
Thu Jul 18 08:23:45 EDT 2002
I am attempting to use r.in.gdal to import a bsb raster chart.  I have
read in the documentation pages for gdal that it supports bsb.  Does
this hold true for GRASS5??  Another problem that I have experienced
with r.in.gdal is the following error:
GBBridgeInitialize() failed to find an suitable GDAL .DLL/.so file.
The following filenames were searched for:
  o libgdal.1.1.so
  o gdal.1.0.so
  o gdal.so.1.0
  o libgdal.so.1
The following locations were searched:
  o /usr/local/grass5/lib
  o System default locations.
System default locations may be influenced by:
LD_LIBRARY_PATH = /usr/local/grass5/lib
ERROR: Unable to initialize GDAL bridge (check libgdal
       installation/LD_LIBRARY_PATH variable).
Is this a user error??  I am using pre3 or pre4, can't remember which
one...  thanks!!
LTJG Kevin Slover, NOAA
GIS Specialist/Meteorologist/Oceanographer
Tropical Prediction Center/Technical Support Branch
11691 SW 17th Street Miami FL 33165
(W) 305-229-4456  (F) 305-553-1264
