[GRASSLIST:4099] Re: r.in.gdal question
Kevin Slover Kevin.Slover at noaa.gov
Thu Jul 18 14:15:41 EDT 2002
Alrighty, got it working, somewhat.  Realized why gdal wasn't installed,
and simply recompiled with the --with/--without flags as needed.  And of
course, after all that, the format that I need to use (.kap) is not
supported, or at least the version that I have..interesting...anyhow,
thanks for all the help out there...
JGillette at rfmd.com wrote:
> Hi Kevin,
> You can go to ftp://ftp.remotesensing.org/pub/gdal/
> download gdal-1.1.7.1-linux-bin.tar.gz
> open it and get the libgdal.1.1.so file.
> Put it in the <grass install>/lib/ directory.
> On my system there is a libdatetime.a and libgis.a there.
> Your r.in.gdal should work after that.
> This will save you having to make it yourself if you
> don't want to.
> John
LTJG Kevin Slover, NOAA
GIS Specialist/Oceanographer
NOAA/TPC/TSB/Storm Surge Unit
11691 SW 17th Street
Miami FL  33165
W (305) 229-4456
