[GRASSLIST:3852] Re: s.surf.idw help
Markus Neteler neteler at itc.it
Tue Jun 11 04:26:51 EDT 2002
On Tue, Jun 11, 2002 at 04:19:35PM +1000, Gordon Keith wrote:
> Sounds like you are running out of swap space.
> I gave up on s.surf.idw on my data set. After I gave it about 3GB of
> swap space it managed to process 3% of the data over a weekend, so I
> killed it.
Consider to use the pre4 version of s.surf.rst (also the RST algorithm
is better than IDW). The module was improved to run > 2000% faster for
dense data.
[snip]
Markus
> On Sat, 8 Jun 2002 01:09, Kevin Slover wrote:
> > I am attempting to use r.surf.idw to create a finer resolution data
> > set for GLOBE data.  Currently, I have imported the data at .001 deg
> > X .001 deg res, and am trying to get to .0005 X .0005 deg res...it
> > starts fine,
> > reading in the input raster, however, will not read the entire
> > raster...
> > When it is reading in the raster, is it storing it to memory before
> > starting the interpolation??  The first time I tried it, the message
> > simply said KILLED.  I tried a second time, reducing the area of
> > interpolation, and it completely froze up my computer.  I am using
> > pre4 ( I think), I downloaded from CVS 2 wks ago, on a RH7.2.  Any
> > thoughts??  I think I might be trying to do too much...just my first
> > guestimate...
> > thanks...
> Gordon Keith
> Programmer/Data Analyst
> Marine Acoustics
> CSIRO Marine Research
> http://www.marine.csiro.au
> "Computers are useless. They can only give you answers."
> - Pablo Picasso, 1968
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
     Project on Predictive Models for the Environment
Via Sommarive, 18        -      38050 Povo (Trento), Italy
tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
