[GRASSLIST:3905] Re: Grass5.0.0pre4 Installation Problems(cont.)
Glynn Clements glynn.clements at virgin.net
Tue Jun 18 11:16:56 EDT 2002
Neil.Murphy at axa.ie wrote:
> I am still trying to install Grass5.0.0pre4 correctly on Mandrake 8.2
> When I try to run grass I get the following as a user or as root
> [neil at localhost bin.i686-pc-linux-gnu]$ ./grass5
> /home/neil/project/grass5.0.0pre4/dist.i686-pc-linux-gnu/etc/Init.sh:
> /home/neil/project/grass5.0.0pre4/dist.i686-pc-linux-gnu/etc/lock: No such
> file or directory
> Unable to properly access /home/neil/.gislock5
> Please notify system personel.
> I notice a previous mail on the list that suggested
> "Try to recompile
> gmake5 -i src/general/init/
> and check if 'lock' is compiled." So I tried this and got the following
[snip]
> make: *** No rule to make target
> `/home/neil/project/grass5.0.0pre4/src/libes/LIB.i686-pc-linux-gnu/libedit.a',
Send me the errors which result from "gmake5 src/libes/edit".
Glynn Clements <glynn.clements at virgin.net>
