[GRASSLIST:3282] Re: Topmodel parameter file
Thomas Adams Thomas.Adams at noaa.gov
Mon Mar 4 09:27:31 EST 2002
Helena & Markus,
I'd be very happy to take on this project, but I'll need some help (guidance) on
doing this. I've used the model & I am pretty familiar with the original code,
but I have NOT written any GRASS modules to date. There is no time like the
present to get started!
Regards,
Tom
Markus Neteler wrote:
> A forward from Helena Mitasova:
> On Sat, Mar 02, 2002 at 07:42:28AM -0600, Helena wrote:
> > > > Well, an example is already in CVS tree: src/raster/r.topmodel/example.
> > > > Two files are available: input and param.
> > > > Would you check these files?
> > > > Best Regards,
> > > > Huidae Cho
> > > ... it seems we all didn't look into the source code :-)
> > > Markus
> Markus
>  I tried to run it with those files - I would need to go back to check what
>  I got, but I believe that I was still missing some necessary information to
>  run it with my own files.
>  As it is now, without a decent manual page that module is difficult to use,
>  unless you go to the original TOPMODEL site and learn about it there or
>  unless you know the original model.
>  The TOPMODEL code is very good and topinx has the multiple flow algorithm
>  which works nicely on hillslopes (too bad that you cannot get the upslope
>  area too from it), so it would be nice if somebody could take it, add
>  additional useful outputs and write decent manual.
>  Perhaps we find someone to write an improved manual page including an
>  example (eventually based on the parameter files in the source code)?
>  Helena
Tom Adams
Development & Operations Hydrologist
NWS-Ohio River Forecast Center
thomas.adams at noaa.gov
http://www.nws.noaa.gov/er/ohrfc/
1901 South State Route 134
Wilmington, OH 45177
(937) 383-0528 (VOICE)
(937) 383-0033 (FAX)
