[GRASSLIST:3628] Re: compilation
Glynn Clements glynn.clements at virgin.net
Tue May 7 11:24:49 EDT 2002
Ulrich Leopold wrote:
> if I compile a single GRASS module as a USER in my HOME directory but
> want to provide it later on the network in /usr/local/..., will it still
> function or is it depend on the directory structure I build it in?
GRASS modules should work from any location; the only requirement is
that the environment variable GISBASE is set accordingly.
Glynn Clements <glynn.clements at virgin.net>
