[GRASSLIST:3676] problem importing e00 files
Allard, Yannick (EXP) yannick.allard at lmco.com
Thu May 16 18:04:28 EDT 2002
I have problem importing .e00 file with grass 5 (and grass4.3). The problem
is for polygon coverage. The export format of arc/info for polygon coverage
do not include any PAL or PAT section but only an AAT section, so grass
doesn't recognize it as a polygon coverage. It is possibly due to a change
in arc/info .e00 file in the new version of arc/info.
in the last version the files were name like ******l.** for lines entity,
******a.** for area but the new version saves area file like ******d.*** for
"line entity delineating an area".
I have try everything that I've saw in the grass list concerning the e00
files but none of them work. I have no problem with m.in.e00 for generating
the vector map but when I try to generate a raster, it just won't work
properly cause no polygon are detected. ( I have also tried to change all L
by A in the files generated by grass but it dont do anything).
Also, editing all the files manually in v.digit would be to much work cause
I have about 250 files to integrate and dont have enough time to do it with
v.digit.
Do anyone has any idea. Any suggestion would be appreciated...
Tanks in advance
Yannick Allard
