[GRASSLIST:3691] Re: Scattergram; r.in.gdal
Henning Lorenz hl at geofys.uu.se
Tue May 21 02:00:17 EDT 2002
Hi John!
Try "r.in.tiff input=xxx output=yyy". It will read the TIF-file and
the associated .tfw-world-file. Not all definitions within tfw are
supported, only upper right coordinate and cell-size. Have look on
the manual page.
Henning
>Hi all. Is there any command to generate a scattergram of
>two rasters? I have read the command list but can't find
>a direct way to do that. Is there any other indirect way
>to build a scattergram?
>I read the emails about r.in.gdal errors sent to the list
>the last week. I am also running into problems trying to
>import tiff files with a .tfw description file into an
>existing location. I generated a location using the UTM
>projection larger than my tiff image. Then r.in.gdal doesn't
>import the tiff file using the info stored in the .tfw
>file and assigns the rows-cols values to the image borders.
>I must then fiddle with the border coordinates using r.support.
>I was wondering if I'm doing something wrong, because I
>expected r.in.gdal to get projection info from the current
>region/location and image coordinates from the multiband
>tiff/.tfw file (?).
>Any comment would be appreciated.
>Thanks in advance,
>John
Henning Lorenz
Uppsala University
Department of Earth Sciences
Villavägen 16
S-752 36 Uppsala
phone:	+46(0)18 471-7161
fax:	+46(0)18 50 11 10
priv.	+46(0)18 463 273
mobil	+46(0)733 622 655
mailto:hl at geofys.uu.se
