[GRASSLIST:3696] Re: Grass5.0.0pre4's 'make install' dies looking for dist.X/locale
Buchan Milne bgmilne at cae.co.za
Tue May 21 08:21:17 EDT 2002
H. Bowman wrote:
 > Grass5.0.0pre4 is out apparently.
 > Kudos to all. Time to beat on the new shape file importers.. :)
 > The configure summary is a nice touch.
 > Configured it (with everything but NLS support), compiled it. No errors.
 > Upon 'make install', it hums though until it gets to this:
 > test -d
 > /usr/src/grass5source/grass5.0.0pre4/dist.i686-pc-linux-gnu/locale &&
 >  /bin/sh -c "cd
 > /usr/src/grass5source/grass5.0.0pre4/dist.i686-pc-linux-gnu ;
 >  tar cBf - locale | (cd /usr/local/grass5 ; tar xBf - ) 2>/dev/null ;
true"
I'm getting the same thing (building RPMs for Mandrake 8.2/cooker -
almost ready ...), and I have a patch against the Makefile.in, which
adds a ';true' after then end of the line above to make make happy.
But it seems make is not doing the right thing with the locales? It
looks like you will only be missing Russian though ....
Buchan
|----------------Registered Linux User #182071-----------------|
Buchan Milne                Mechanical Engineer, Network Manager
Cellphone * Work            +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering         http://www.cae.co.za
GPG Key                   http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
