[GRASSLIST:4940] Re: gmake5 woes
Glynn Clements glynn.clements at virgin.net
Tue Nov 12 17:23:29 EST 2002
H. Bowman wrote:
> Today I recompiled the GRASS sources with the new Tcl/Tk 8.4 and libpng2,
> but had to revert to Tcl/Tk 8.3 due a to NVIZ compile error, and now
> gmake5 doesn't make good post-compile modules.
> wish and related symlinks seem to be pointing back to tcl8.3 versions, and
> this was done before I compiled the main package.
> Not trusting 'make distclean', I uninstalled and started afresh from the
> .tar.gz package, which goes fine, and I can reinstall and run grass
> without problems. If I throw my modified module in the source tree before
> starting, it makes it in and everything works fine.
Notes:
1. If you make any changes to the development environment (libraries,
header files, compilers etc), you need to re-run "configure".
2. There is also "make maintainer-clean", which does a bit more than
"make distclean".
> However, if I later compile a modified module with gmake5, and then copy
> the new binary to /usr/local/grass5/bin/ (with grass running), strange
> things start happening.
I bet they do ;)
The actual modules go into $GISBASE/etc/bin/cmd or
$GISBASE/etc/bin/inter. Nearly everything in $GISBASE/bin is actually
a hard link to $GISBASE/etc/front.end.
This program runs the appropriate module from either
$GISBASE/etc/bin/cmd or $GISBASE/etc/bin/inter; if no arguments were
given and an "inter" version exists, that is run, otherwise the "cmd"
version is run.
> Specifically, within grass, ANY binary grass module I run will execute my
> new module, but if I pass the 'help' option, the 'Usage:' line lists the
> name of the module I tried to run with the rest of the help screen from my
> module. The only thing that works properly is the new module (which is
> your only option anyway..).
You have overwritten $GISBASE/etc/front.end with your program; you
should re-install GRASS with "make install".
Glynn Clements <glynn.clements at virgin.net>
