[GRASSLIST:5029] Re: surface roughness
jprs jprigol at ujaen.es
Thu Nov 21 11:03:00 EST 2002
> Does anyone know how I can make a surface roughness map?
> the map is made by dividing the area into square inuts, and then
> calculating
> the ratio beetwen the real area and the planar area of each cell.
> the basic problem is how to calculate the real area of the
> surface in each
> cell.
If I've understood your question...
I guess you'll have to divide by the cosin() of the slope,
but why don't you use the stdv or similar within a window?
Regards,
Juan
