[GRASSLIST:5060] Re: export images
Glynn Clements glynn.clements at virgin.net
Mon Nov 25 13:35:06 EST 2002
andres javier garcia garcia wrote:
> Is there any command to export a image from what I have in my display monitor?
> It is a stack of raster, overlayed by sites and vect maps.
You can use the PNG driver ("d.mon start=PNG") to direct the output of
d.* commands into a PNG image.
You can use d.save to obtain a script of the commands which were used
to generate the display on the current monitor.
Glynn Clements <glynn.clements at virgin.net>
