[GRASSLIST:5072] Re: r3out.v5d(?) problem
John Harrop johnh at sjgeophysics.com
Mon Nov 25 20:59:03 EST 2002
I just regridded (s.vol.v5d) with a grid using equal number of row and
columns (but not depths).  Now it works, although I'm still checking to
see if its mirrored or otherwise messed up.  I usually assume that my
code (s.in.ubcgif in this case) is causing the problems.  But then
showdspf should not be working.
Cheers,
John Harrop
