[GRASSLIST:4891] Re: ID given Distance from a given point's ID
Christoph Hoegl C.Hoegl at gmx.net
Tue Nov 5 16:36:28 EST 2002
Have a look at the
s.voronoi
manpage
sth like this might work for you:
It creates areas of "closeness"
You may "color" your map according to the ID of the nearest point
(catnum option)
so all new points are automatically on their green:-)
#---------snip-------------
r.mapcalc 'roundmap=round(map)' # cause s.voronoi works only with integers
r.to.sites input=roundmap output=roundmap.sites # convert to
# 	sites as s.voronoi works only with sites
s.voronoi  sites=roundmap.sites vect=closest.vect # creates closeness diagrams
v.to.rast input=closest.vect output=closest.rast # optionally convert to
#	raster
# you may display and query using
d.rast closest.rast
d.vect closest.vect
d.what.vect closest.vect
#---------snip--------------
kind
regards,
Christoph
