[GRASSLIST:4904] Re: v.proj question
Markus Neteler neteler at itc.it
Thu Nov 7 12:28:00 EST 2002
On Thu, Oct 31, 2002 at 10:52:57AM +0100, michele.rocc at libero.it wrote:
> Hi,
> I neeed to perform a conversion of a isolines vector map, not really
> a datum conversion but a "fuse conversion" because two adiacent maps
> has coordinates referred to two different fuses.
> Is v.proj useful to do this or is it still limited to nad27 - nad83
> conversion as specified in the man page?
> In this case is there another way to perform this tipe of conversion
> (for examp. reproject UTM(WGS84) Fuse 33N vector map to UTM(WGS84) Fuse
> 32N)?
You are right: Italian fuse conversion is no datum transformation
(AFAIK). So v.proj will work fine for that.
Cheers
 Markus
