[GRASSLIST:4624] Re: GRASS and Linux kernels
Russell Senior seniorr at aracnet.com
Thu Oct 3 08:32:04 EDT 2002
>>>>> "Nigel" == Nigel McFarlane <nrm at kingtide.com.au> writes:
Nigel> I thought I'd just pass on my experiences with GRASS on Linux.
Nigel> I've been doing heavy processing using RedHat Linux 7.2, which
Nigel> is kernel 2.4.7-10. I'm typically using 98% of available
Nigel> memory, but without swapping or paging.
You don't provide quite enough information to be sure, but it sounds
like you've hit on a common misconception.  It is _normal_ to "use all
available memory" on Linux. Looking at "top" output for example,
you'll find that much of the used memory is being "consumed" in
buffers and cache.  That memory is immediately releaseable should an
application require it.  In Linux, just try to remember the adage:
"free memory is wasted memory".
On the other hand, I am not intimately familiar with your specific
situation, so I may have misinterpretted.  If that's the case: "never
mind". ;-)
Russell Senior         ``I've seen every kind of critter God ever made,
seniorr at aracnet.com      and I ain't never seen a meaner, lower, more
                         stinkin' yellow hypocrite than you!''
                                        -- Burl Ives as Rufus Hennessy
