[GRASSLIST:4663] RE: Categories in v.in.dxf
Antonio Uriarte
antoniouriarte at terra.es
Sun Oct 6 19:28:09 EDT 2002
I think that there is an option "category=", isn't there? Try with
category=Layer or category=Elevation.
Antonio Uriarte.
----- Original Message -----
To: <grasslist at baylor.edu>
Sent: Saturday, October 05, 2002 9:57 PM
Subject: [GRASSLIST:4659] Categories in v.in.dxf
> Hello,
> I still did not unterstand how does v.in.dxf work. Whenever I import .dxf
> files into Grass5.0.0, I get a Grass vector file with cataegories of "no
> data". Then I run v.support followed by v.digit where I choose to bulk
label
> all the lines in the file (e.g. 1). This seems to append 1 to labels as
well
> as categories (or not?). The described procedure seems fine if you want to
> rasterize the lines but if you want to measure the cumulative length of
all
> the vectors with v.report you still get no result.
> category meters
> 1...........................0.0000
> The "label=" in v.in.dxf command seems only for appending suffixes to
> different layers of the .dxf file.
> I also tried the v.cadlabel command but appearently with no success.
> The question remains. How can I measure the length of all the lines in an
> imported .dxf file?
> Miha Staut
> _________________________________________________________________
> Chat with friends online, try MSN Messenger: http://messenger.msn.com
