[GRASSLIST:4684] Re: climatics stations & time series interpolation
Kevin Slover Kevin.Slover at noaa.gov
Tue Oct 8 12:57:49 EDT 2002
Javier,
    I have actually written a script that does just what you are asking, I
believe.  I had the problem of wanting to import ~150 ascii text files into
grass.  It is extremely archaic, as my computing skills are well sub-par.  It is
a simple shell script, but it got the job done.  I would be very happy to share
it with you, if you are interested...
andres javier garcia garcia wrote:
> Hi all;
> Maybe I'm late in this topic. I've got data from climatic stations, and I
> could use, by example, s.surf.rst to interpolate the data; but I've got these
> data in a daily mode, for several years.
> I would like to use the ascii files to make an interpolation for everyone of
> the time steps.
> Is there a script, or a program in GRASS, to do this?
> If not. Do you think it is a good idea to make this script?
> I could try, although my skills in computing don't go far.
> Thanks for your help and opinions.
> Javier Garcia
LTJG Kevin Slover, NOAA
GIS Specialist/Oceanographer
NOAA/TPC/TSB/Storm Surge Unit
11691 SW 17th Street
Miami FL  33165
W (305) 229-4456
