[GRASSLIST:4692] Re: updated interpolation
Jaro Hofierka jhofier at unity.ncsu.edu
Wed Oct 9 10:14:19 EDT 2002
Check if the s.surf.rst is taking the right z-values from your site
file. Then run it with default values (tension, smooth, etc.).
J.
orkun wrote:
> Hello
> when I interpolated my site map with using spline-tension method, I
> got a raster map containing meaningless negative output values despite
> the fact that I have only positive input values.
> why does spline tension method output negative values from
> positive input data ?
> anyone has an idea?
> thanks in advance
