[GRASSLIST:4740] Re: r.in.gdal mystery - Landsat
Eric G. Miller egm2 at jps.net
Mon Oct 14 13:13:05 EDT 2002
On Mon, Oct 14, 2002 at 06:12:54PM +0200, andres javier garcia garcia wrote:
> When I run r.in.gdal; and I'm not sure about the proper file to use as input
> for Landsat7, because there are several files. I've tried to give to driver
> everyone of the three administrative files, and I get:
> ERROR 4: `L71199000_00020010726_HPN.FST' not recognised as a supported file
> format.
> ERROR 4: `L71199000_00020010726_HRF.FST' not recognised as a supported file
> format.
> ERROR 4: `L71199000_00020010726_HTM.FST' not recognised as a supported file
> format.
> So, I don't know what to do. Are these files the correct input?
Which indicates r.in.gdal is working properly but doesn't recognize the
file format.  Do you know what the file format is? Perhaps changing the
extension will help gdal pick the right translator...?
static const char signature[] =
	"Copyright (c) 2002 Eric G. Miller <egm2 at jps.net>";
