[GRASSLIST:4750] batch jobs
Martin Wegmann m.wegmann at web.de
Tue Oct 15 21:57:09 EDT 2002
hello,
I have a couple of commands which I have to run on each image. Would it be possible to merge these commands and only change the input and output each time for each image?
like input=map1 output=map1a
command x  in=map1 out=x
command y  in=x out=y
and so on until the final out=map1a
as far as I understood the use of shell scripts, they are desigend to do this. But how do I write them and load them into GRASS?
thanks for your help,
Martin
Martin Wegmann
Tropical Ecosystem Research Center
PMB 44 Winnellie / Darwin
NT 0821
Australia
priv.
4 Carpentier Cres.
Wagaman / Darwin
NT 0810
Autralia
0061 8 8927 1241
