[GRASSLIST:4768] Re: error when starting grass5 - corrected
Glynn Clements glynn.clements at virgin.net
Thu Oct 17 19:51:11 EDT 2002
Holger Zebner wrote:
> I need help on starting my new installed GRASS 5.0 (on SuSE 7.1).
> After I have typed the "grass5" command I get the info (Welcome to
> blabla...) msg and then I press return. After that I get the error msg
> "/usr/local/grass5/etc/set_data: error while loading shared libaries:
> libtermcap.so.2: cannot open shared object file: No such file or directory"
> What can I do?
Check whether SuSE provides a "libtermcap" package.
Glynn Clements <glynn.clements at virgin.net>
