[GRASSLIST:4786] Re: error when starting grass5 - corrected
Holger Zebner holgerzebner at gmx.de
Sun Oct 20 13:12:16 EDT 2002
Thank you Malte, it worked well. Maybe they should write about it in the
Install.txt since there were a few having the same problem.
At 08:51 19.10.02 +0200, you wrote:
>Hi Holger!
>I Got Grass5 running on Suse 7.2 and it works fine. The library is
>somewhere on the system, but SuSe had another name for it. Unfortunally I
>don't know exactly the new name, but there were several postings in this
>maiilinglist dealing with that problem a few months ago. So you should
>take a look at the mailing list archieve.
>When you found it you just have to create a link to the library.
>Malte
>On Fri, 18 Oct 2002, Holger Zebner wrote:
> > I have checked my current setup for libtermcap but it couldn't be located.
> > Where (in my filesys) should it be? From where could I get it if SuSe
> > doesn't have it?
> > Thanks
> > Holger
> > > > I need help on starting my new installed GRASS 5.0 (on SuSE 7.1).
> > > > After I have typed the "grass5" command I get the info (Welcome to
> > > > blabla...) msg and then I press return. After that I get the error msg
> > > > "/usr/local/grass5/etc/set_data: error while loading shared libaries:
> > > > libtermcap.so.2: cannot open shared object file: No such file or
> directory"
> > > > What can I do?
> > >Check whether SuSE provides a "libtermcap" package.
> > >Glynn Clements <glynn.clements at virgin.net>
