[GRASSLIST:4798] RE: G.region
Byars, Bruce W. Bruce_Byars at baylor.edu
Tue Oct 22 13:21:53 EDT 2002
Alexandra,
You will have to select your monitor using d.select
when you have more than one monitor open (refer to
the DEFAULT_WIND description here for more info).
When you define your region in one monitor and save
it, simply select that region in your other monitor(s).
Hope this helps.
Bruce
-----Original Message-----
From: Alexandra Zamparas [mailto:kat at nada.kth.se]
Sent: Tuesday, October 22, 2002 9:54 AM
To: GRASSLIST
Subject: [GRASSLIST:4796] G.region
Thanks for the replies on exporting a raster. I would like to ask
another question now: I have a raster (elevation), I do d.zoom and
choose the area, do g.region to see the new coordinates and then
perform r.fill.dir which is done in that region. So far, so good.
When I display again elevation in another monitor the raster has
different coordinates. Is g.region monitor dependent? (maybe this is
too simple a question but I don't know). How do I set the new region
in another monitor?
Regards,
Alexandra
