[GRASSLIST:4808] Re: Alternate ODBCs in SuSE 8.1
Glynn Clements glynn.clements at virgin.net
Wed Oct 23 03:45:45 EDT 2002
John Dougherty wrote:
> I just recompiled GRASS 5.0 for SuSE 8.1.  Most of the process proved
> reasonably straightforward.  However, the ODB library(ies) proved a little
> problematic.  There are obdc libs installed with main installation, however
> GRASS seems to be in need of the unixODBC, or at least that seemed to be what
> solved the problem.  SuSE however, alerts repeatedly that the unixODBC and
> the libodbc already installed can cause conflicts and may destablize the
> system.  Are there any recommendations about handling this from the GRASS
> team?
Install UnixODBC where other programs won't find it, i.e. somewhere
other than /usr/{include,lib} or /usr/local/{include,lib}; e.g.
/opt/UnixODBC/{include,lib}.
When configuring GRASS, use --with-odbc-includes= and
--with-odbc-libs= to tell the configure script where to find it.
Once GRASS has been installed, add the library directory (e.g.
/opt/UnixODBC/lib) to the LD_LIBRARY_PATH setting in
$GISBASE/etc/Init.sh.
However, this typically won't work if you use tcltkgrass and xterm is
setuid root, as setuid programs discard the value of LD_LIBRARY_PATH.
In that case, build a static version of the UnixODBC library instead
of a shared library (use --enable-static and --disable-shared).
Glynn Clements <glynn.clements at virgin.net>
