[GRASSLIST:4868] Re: copying regions between systems
Glynn Clements glynn.clements at virgin.net
Thu Oct 31 19:02:54 EST 2002
cbsled at ncia.net wrote:
> Can I simply tar up the region's dir in the database and copy it to
> another machine?
> Or is there more to it than that, and if so, what?
Are you referring to a "location" directory? If so, then you can
safely transfer the directory to another machine of the same
architecture.
For machines of differing architectures, the situation isn't so clear
cut. Any ASCII files (WIND, cell_hd, colr, sites etc) are portable, as
are the cell files. I don't know about vector files. Some modules may
create additional files using their own private format, and some of
these aren't portable (e.g. the raw FFT output from i.fft).
Glynn Clements <glynn.clements at virgin.net>
