[GRASSLIST:4542] Re: Raster to vect. A simple question?
Eric G. Miller
egm2 at jps.net
Fri Sep 20 01:57:45 EDT 2002
On Fri, Sep 20, 2002 at 12:07:57AM -0500, Camilo Castiblanco wrote:
> Dear andres
> You can to obtain a contour map (vector map) with the command r.contour.
Methinks the OP wants r.poly to create a vector outline of a raster
watershed (an area, not a surface).
> With the command v.out.dxf you get the dxf map
> ----- Original Message -----
> From: "andres javier garcia garcia" <andresjavier.garcia at wanadoo.es>
> To: "GRASS LIST" <GRASSLIST at baylor.edu>
> Sent: Thursday, September 19, 2002 9:38 AM
> Subject: [GRASSLIST:4535] Raster to vect. A simple question?
> > I need to obtain a dxf file from a raster map. This map is just 1 for a
> > watershed and null for the rest.
> > How could I do this?
> > I've tried and I can't see the way.
begin 664 .signature
M<F5L;&E-("Y'(&-I<D4@/G1E;BYS<&I`,FUG93P)"`@("`@("`@("`@("`@(
M"`@("`@("`@("`@("`@("`A%<FEC($<N($UI;&QE<B`\96=M,D!J<',N;F5T
"/@H`
end
