[GRASSLIST:4550] Re: Interpolation using digitized or rasterized contours
Xueming Wu xwu at cse.unl.edu
Fri Sep 20 10:20:59 EDT 2002
Hi Antonio,
The resolution set in the g.region will affect the running
time of v.surf.rst. The higer resolution you use the more
time you need. You can try to use lower resolution to save
time.
Good Luck,
Xueming
