[GRASSLIST:5967] HELP! v.in.shp and database
Schuyler Fishman schuylerfish at earthlink.net
Sat Apr 5 14:22:56 EST 2003
The manual says there is a command v.in.shape.pg that build the entire
database file from the esri shape file. does anyone know why when I
type this it says command not found?
Also - if this command does not exists - how do I go about creating the
attribute database for the grass vector file once I have imported it
with v.in.shape.
Is there a GRASS database tutorial?
THANKS
Schuyler Fishman
Schuylerfish at earthlink.net
www.mindlikesky.com
