[GRASSLIST:5977] Re: Postgress and GRASS CD
John Chesnut jchesnut at slonet.org
Tue Apr 8 19:01:40 EDT 2003
Can some one who has experience getting  Postgres interoperating with
Grass on Mac OSX please post step by step instructions.
The initdb command will create a "data" directory, but the postgres
server fails on startup. The initdb command requires su as the
"postgres" user
	su postgres
	/usr/local/pgsql/bin/initdb -D /usr/local/pgsql/data
complete successfully.
Several issues are apparent
1. Postmaster does not successufully start using the terminal command
postmaster (eg.
	 sudo -u postgres /usr/local/pgsql/bin/postmaster -i -D
this reports the error
	FATAL:  no such group 'pgsql'
	/usr/local/pgsql/bin/postmaster: cannot create UNIX stream port
my interpretation:  some parts of postmaster need write permission
with group pgsql which is not created by MacOSX
2, attempting to open the postmaster with the command
	 sudo -u pgsql /usr/local/pgsql/bin/postmaster -i -D
yield the error
	FATAL 1:  cannot open /usr/local/pgsql/data/PG_VERSION:
Permission denied
my interpretation:  requires read permission of user "postgres" which
is lacking for user pgsql
(I created the alternative user pgsql in an attempt to start postmaster)
3. attempting to start postmaster using the pg_ctl script as either
user postgres or pgsql yields a similar error.
	sudo -u root sudo -u pgsql /usr/local/pgsql/bin/pg_ctl start
this returns a message
	postmaster successfully started
Permission denied
same error as 2.
Evidently getting the postmaster/postgres server running need
alterations of permissions and groups, but no documentation is
available that explains how to create a "pgsql" group and associate
it with a "postgres" user.
Changing the /usr/local/pgsql/data directory permissions to 777 or
766 yields an fatal error that permissions are incorrect: so simply
expanding permissions doesn't work. The error reported is:
FATAL 1:  data directory /usr/local/pgsql/data has group or world
access; permissions should be u=rwx (0700)
trying to create a user from within postgres as in
	sudo -u postgres /usr/local/pgsql/bin/createuser jchesnut
fails because
	psql: could not connect to server: No such file or directory
       		 Is the server running locally and accepting
        		connections on Unix domain socket "/tmp/.s.PGSQL.5432"?
my interpretation:  postmaster / postgres must be running before the
createuser command can be issued.  postgres wont run because of the
fatal errors listed above.
Please help, if you know how to get postgres running under OSX
