[GRASSLIST:5997] Re: v.support after dxf-import
Heiko.Kehlenbrink at vermes.fh-oldenburg.de Heiko.Kehlenbrink at vermes.fh-oldenburg.de
Thu Apr 10 02:40:17 EDT 2003
hi paul,
great work, your script fixed my prob!
best regards
heiko kehlenbrink
> On Wed, 9 Apr 2003 Heiko.Kehlenbrink at vermes.fh-oldenburg.de wrote:
> > hi all,
> > got some probs running v.support on a vectorfile i imported with
> v.in.dxf.
> > after v.support the dig_att was empty.
> Try the solution here and see if it works:
> http://op.gfz-potsdam.de/GRASS-List/Archive/msg08556.html
> Let us know if it does; maybe v.in.dxf needs to be fixed.
> (You can probably ignore the references to v.in.dxf3d but you will need
> to
> run v.in.dxf again and run the script before doing v.support. And
> there
> might still be other problems.)
> Paul
