[GRASSLIST:6052] Re: Questions
Glynn Clements glynn.clements at virgin.net
Mon Apr 14 11:19:29 EDT 2003
Edmund Blackadder wrote:
> Well, i get the prize for the most descriptive subject...
> Anyway, i use GRASS for some time now. I used the binaries and with
> your help through this list i have only minor problems.
> But I decided to compile the 5.0.1 source yesterday.
> Compilation was ok (i directed with options most things to /sw/include
> and /sw/lib).
> The only warning in the configure script was fot the iconv() and
> gettext() function. (undefined functions).
These are harmless.
iconv() is only used by d.text.freetype; if you don't have iconv(),
d.text.freetype still works (assuming it was actually built, which
requires FreeType support), but it can only handle Western
(ISO-8859-1, aka ISO-Latin1) text.
gettext() is only used if you use --with-nls to get natural language
support. Currently, only Russian is supported, and only for parts of
GRASS (libgis, libraster, the PostgreSQL modules, and a couple of
other programs).
Neither of these are related to the tcltkgrass problem. Either set the
environment variable GRASS_WISH to the name of your "wish" program (it
may include the version number, e.g. "wish8.3"), or create a symlink
called "wish" pointing to the actual wish program.
Glynn Clements <glynn.clements at virgin.net>
