[GRASSLIST:6065] Re: Getting NVIZ to work
Glynn Clements glynn.clements at virgin.net
Wed Apr 16 09:21:34 EDT 2003
Markus Neteler wrote:
> > /opt/grass/grass5/etc/nviz2.2/NVWISH2.2: error while loading shared libraries: libtcl.so.0: cannot load shared object file: No such file or directory
> The tcl/tk library/ies are missing
Or they aren't compatible.
1. I don't know about RH7.1, but on RH6.2 the library name include the
version number (e.g. libtk8.0.so). Creating a symlink *might* work,
but see the next point.
2. You have to have the same version of Tk as was used for building
NVIZ; if NVIZ was built for Tk 8.3, then you have to have Tk 8.3 to
run it.
Glynn Clements <glynn.clements at virgin.net>
