[GRASSLIST:6077] Re: 5.0.2 problem
Otto Dassau otto.dassau at gmx.de
Thu Apr 17 12:19:12 EDT 2003
Hi Martin,
for me this error message for NVIZ appears
when I tried to use the package from
http://grass.itc.it/grass5/binary/linux/nviz_postgresql_tk83_i686-pc-linux-gnu_.tar.gz
which was compiled on Redhat with Tcltk 8.3.
If you use Tcltk 8.4 maybe you should try the
other package compiled on SuSe 8.1. This hopefully
works for you ...
http://grass.itc.it/grass5/binary/linux/nviz_postgresql_tk84_i686-pc-linux-gnu_.tar.gz
  Otto
> I downloaded the GRASS 5.0.2  binary
> but when I start NVIZ I can choose raster, vector maps etc. but instead of a
> display the following error message appears - it looks similar to the error
> prompt of my previous GRASS version when it didn't support tc/tkl 8.4 as far
> as I can judge it ;-).
> BTW the command r.series, r.mapcalc3 etc. all the new one are not found in
> grass 5.0.2 (>command not found), I tought that I downloaded the old one by
> mistake but I recognized some changes in the interface and the GRASS info
> tells me as well that it is 5.0.2.
> any idea? otherwise I will try the source code .
> cheers Martin
> The papers are available at
> http://www2.gis.uiuc.edu:2280/modviz/
> Loading Data
> building color table
> Adding panels from /usr/local/grass5/etc/nviz2.2/scripts
> Nv_(panels)
> toplevel made
> child killed: segmentation violation
>     while executing
> "exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
> /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=00l -name NVIZ
> >&@stdout"
>     ("eval" body line 1)
>     invoked from within
> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
>     invoked from within
> "if {$argv == ""} {
> #no arguments
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
>     (file "/usr/local/grass5/bin/nviz" line 16)
