[GRASSLIST:6104] NVIZ problem
orkun temiz at deprem.gov.tr
Tue Apr 22 07:53:01 EDT 2003
Hello
I encounter a problem using NVIZ in grass5 and rh 9.
I tried to fix the problem by soft link of libtk.so.0 to
libtk.so. But the problem is not solved.
what do you recommend me ?
Here is the error message:
/usr/local/grass5/etc/nviz2.2/NVWISH2.2: error while loading shared
libraries: libtk.so.0: cannot open shared object file: No such file or
directory
child process exited abnormally
     while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=f28elv2 -name
NVIZ >&@stdout"
     ("eval" body line 1)
     invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
     invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
     (file "/usr/local/grass5/bin/nviz" line 16)
thanks inadvance
Ahmet Temiz
______________________________________
Scanned and protected by Inflex
http://pldaniels.com/inflex
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
