[GRASSLIST:6108] Re: grass5 non-interactively
Stephan Holl sholl at gmx.net
Tue Apr 22 11:54:36 EDT 2003
At Mon, 31 Mar 2003 10:50:17 +0100 Glynn Clements wrote:
Hello Glynn,
>  The location/mapset environment variables are correctly defined, the
> > grass5 starts without the initial dialogue and gets immediately to
> > grass shell, but then it does not run my perl script.
> Setting the environment variable SHELL to the path to the perl script
> should work, e.g.
> 	SHELL=/path/to/script.pl grass5 /path/to/dbase/location/mapset
with reference to this old thread I cannot make grass work as a
non-interactive session from cron.
I would like to run some simple commands like g.list rast without any
user-interaction.
this is the shell-script:
#!/bin/sh
g.list rast >> raster-files.txt
exit
but the above SHELL-command does not produce any output...
thanks for your help
cheers
  Stephan Holl
Stephan Holl
GnuPG Key-ID: 11946A09
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20030422/59fb1a83/attachment.bin
