[GRASSLIST:6117] Re: Trouble getting grass started
Buchan Milne bgmilne at cae.co.za
Wed Apr 23 11:39:20 EDT 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Glynn Clements wrote:
> You need an X server in order to use tcltkgrass or NVIZ. XFree86 is
> available for Cygwin, although the last time that I tried it was
> definitely "beta" quality.
> I'm not sure that tcltkgrass is really worth the effort of installing
> XFree86. Unless you want to use NVIZ (in which case, and X server is
> necessary), you may as well stick to the command-line interface.
Or just bite the bullet and install Mandrake 9.1 with grass from contrib
(or 5.0.2 from my site, still requires some packages from contrib).
Really, setting up a linux dual-boot (if you have some free space) with
grass is much easier than getting Grass/Cygwin/XFree86 working well.
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne                Mechanical Engineer, Network Manager
Cellphone * Work            +27 82 472 2231 * +27 21 8828820x121
Stellenbosch Automotive Engineering         http://www.cae.co.za
GPG Key                   http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.1 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE+prOorJK6UGDSBKcRApSAAJ9xSfAEMMsIZ47jIm9e5UKTwkHrqQCgjmFt
ojMXhbA3nfgDeCxHu0d2P7c=
=ff9E
-----END PGP SIGNATURE-----
