[GRASSLIST:1925] Re: pie/bar chart of vect variables in 5.0.x
Mon Dec 1 09:09:09 EST 2003
> Or I upgrade to 5.1. but as long as it is not meant for productiv use,
> I prefer to keep 5.0.x.
that doesn't mean you can't use it for production use! ;)
nothing to be afraid of, it works. You can install both 5.0.x and
5.7 (ie 5.1) on the same machine and run each when you need it.
> I transfered data values of 66 plots from R to GRASS using sites.put()
> and plotted their values via the v.bubble command on the background of
> a raster image.
> I wonder if a pie chart or bar chart is as well available this
> way. I looked for d.vect.chart but that seems to be only available
> in >5.1. Is it due to the limit of one variable/vector in 5.0.x?
If you can get it into a raster layer:
d.histogram style=pie
Hamish
