[GRASSLIST:2057] Re: mail and i.rectify
Tue Dec 16 04:46:28 EST 2003
> There is an invisible startup file in your home folder called
> .grassrc5.  You can disable the mail thing by adding a line to it:
> GRASS_STDERR: 1
> BBEdit can open invisible files, otherwise use something like
> TinkerTool to temporarily make it visible and use another text editor
> (you may need to remove the leading dot to edit it, and make sure you
> use Plain Text, UNIX line endings).  Argh, this is getting messy for
> trying to do this with non-command-line stuff.  If you know how to use
> one of the CLI editors (I don't), that would be another method.  Maybe
> someone else knows a simple CLI command to add a line to a file.
May I recommend the nedit package from Fink. (I imagine vi would only
upset someone who purchased a Mac.)
H
