[GRASSLIST:2073] Compile 5.7 CVS on Mac OS X
David Orme d.orme at imperial.ac.uk
Wed Dec 17 08:09:40 EST 2003
I'm trying to install grass5.7 from the weekly CVS snapshots
(2003_12_13 versions) on Mac OS 10.2.8. I've configured the install as
follows:
> bash-2.05a$ CFLAGS="-g -Wall" ./configure
> --with-grass50=//usr/local/src/grass53_exp_2003_12_13
> --with-postgres-includes=/usr/local/pgsql/include/
> --with-postgres-libs=/usr/local/pgsql/lib/ --with-opengl=no
> bash-2.05a$ make mix
> bash-2.05a$ make
and then the make fails with:
> /usr/bin/libtool: can't locate file for: -lpq
> /usr/bin/libtool: file: -lpq is not an object file (not allowed in a
> library)
> make[3]: ***
> [/usr/local/src/grass57_exp_2003_12_13/dist.powerpc-apple-darwin6.8/
> lib/libgrass_vect.dylib] Error 1
> make[2]: *** [subdirs] Error 1
> make[1]: *** [subdirs] Error 1
> make: *** [default] Error 1
Looking about on the web, I think this means it is failing to find a
postgresql library, but the configure does include a pointer to those
libs
any suggestions?
Thanks,
david
