[GRASSLIST:5484] Re: Fwd: Re: v.in.dgn compile with error (new error)
Thu Feb 6 09:06:59 EST 2003
Miguel Cordero wrote:
> Thanks, now this is OK.
> but...  I get a new error !!!
> I tried with
> gdal-1.1.8.tar.gz in http://remotesensing.org/gdal/
> dgnlib-1.6.zip in http://gdal.velocet.ca/projects/dgn/
> but the result is the same.
> With grass5.0.1 and grass50_exp_2003_01_24 there are some differences,  but
> talk about the same funcitions.
Miguel,
I haven't been following this thread closely.  Note that gdal-1.1.8 *includes*
all of dgnlib so you shouldn't generally need both.  If you can force
v.in.dgn to link against libgdal.1.1.so you should be fine.  The only
caveat is the need to "install" the dgnlib include files somewhere they
can be found.  This can be achieved by copying the contents of
../gdal-1.1.8/ogr/ogrsf_frmts/dgn/*.h to /usr/local/include or whereever
the other gdal include files were installed.
Best regards,
