[GRASSLIST:5559] RE: Assigning colours to vectors
Eric G. Miller egm2 at jps.net
Fri Feb 14 21:44:59 EST 2003
On Fri, Feb 14, 2003 at 03:15:41PM -0500, John Gillette wrote:
> Try d.vect.line and d.vect.area
> You can assign a legend file to map category to color.
> I am going to guess that the "standard colors" are the ones defined in
> D_translate_color() and are lower case:
Yes.  Note, d.vect.area and d.vect.line are not limited to those colors.
echo ">gra.fcw at 2ztr< eryyvZ .T pveR" | rot13 | reverse
