[GRASSLIST:5673] Re: dem interpolation
Roger Bivand Roger.Bivand at nhh.no
Wed Feb 26 03:59:06 EST 2003
On Wed, 26 Feb 2003, javier garcia - CEBAS wrote:
> Hi;
> I've got two questions:
> 1) Which process would you advice to be used to obtain a dem from point data:
> (idw, geostatistics, splines)?
Depends rather on your data and needs. Section 7.4, pp. 163-181 of Neteler
and Mitasova (2002) Open Source GIS: a GRASS GIS approach discusses
s.voronoi, s.surf.idw, s.surf.rst, and concludes with advice about choice
of methods.
> 2) There are some GRASS program to get a dem from points data and contours
> levels? I've got both data for a site.
For contours you can also use: r.surf.contour, which uses "procedures
similar to manual methods".
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
