[GRASSLIST:5265] ARCViewImport too slow
javier garcia andresjavier.garcia at wanadoo.es
Fri Jan 3 13:25:57 EST 2003
Hello all and happy new year!
I'm working with someone who uses ArcView and I need a dem that is stored in
his ArcView. We are having serious problem importing it. In fact we can't do
it.
We have export it as a shape file from ArcView. And I'm using r.in.shape to
import it. The translation into a ascii file is slow but a file is obtained
(A 4.5 millions of lines one!), but r.in.poly is dispiriting slow.
After 14 hours it is in the third pass of 26.
I've stopped it because this is clearly not a good method to operate.
Has anyone made this kind of ArcView export-GRASS import with distributed
data as a dem with success?
Thanks and regards
A. Javier García
Water and Soil Conservation Department
CEBAS-CSIC
Apartado 4195
30080 Murcia
Spain
Tel.: +34 968 39 63 90
Fax: +34 968 39 62 13
