[GRASSLIST:5280] Re: No vector display
Markus Neteler neteler at itc.it
Wed Jan 8 05:35:27 EST 2003
On Wed, Jan 08, 2003 at 10:13:10AM +0530, Vidya Kotamraju wrote:
> Hi all,
> I have a vector ascii file for lines.
> The header information and format of the file is as follows...
> ORGANIZATION:NATINAL INSTITUTE OF OCEANOGRAPHY
> DIGIT DATE:  2002
> DIGIT NAME:  grass
> MAP NAME:    globedem_goa_vout
> MAP DATE:    2002
> MAP SCALE:   1
> OTHER INFO:  /home/vidyakr/grass5/GrassData/test/PERMANENT/dig_cats
> ZONE:        0
> WEST EDGE:   73.5999984741211
> EAST EDGE:   74.5916651925072
> SOUTH EDGE:  15.0583334853873
> NORTH EDGE:  15.8000001907349
> MAP THRESH:  00.00
> VERTI:
> L 6
>  73.941 15.425
>  73.942 15.424
>  73.942 15.424
>  73.943 15.424
>  73.944 15.423
>  73.944 15.423
> L 14
>  73.939 15.425
>  73.939 15.424
As far as I see, the order of coordinates is wrong.
For some strange reasons it wants the order:
 N E
(you have the common E N order).
DIGIT DATE:  2002
DIGIT NAME:  grass
MAP DATE:    2002
MAP SCALE:   1
ZONE:        0
MAP THRESH:  00.00
VERTI:
L 6
 15.425 73.941
 15.424 73.942
This order should work.
[... no idea here...]
Cheers
 Markus
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
      Project on Predictive Models for the Environment
Via Sommarive, 18        -       38050 Povo (Trento), Italy
tel +39 0461 314 520 (fax -591)           http://mpa.itc.it
