[GRASSLIST:5316] Re: Compiling grass5.0.0
Glynn Clements glynn.clements at virgin.net
Wed Jan 15 20:39:52 EST 2003
Sjors wrote:
> I'm wondering if anybody tried compilng grass5.0.0 under redhat8.0. I  seem
> to get a lot of errors.
What errors, exactly?
> Is the problem gcc3 and should I revert to  gcc 2.98?
There are a few problems with gcc 3, primarily related to the fact
that it seems to default to C99. The result is that files which define
a function called round() fail to compile. However, most of GRASS5
should still compile.
> I've attached the config.log, don't mind the failure with  postgres. The
> header is somehow not installed. <br>
config.log is only relevant to configure failures, not build failures.
> Another question: are the grid3d modules still in experimental head and  can
> they be compiled with normal grass5.0.0 source?? <br>
The G3D code is currently being developed; fixes have been committed
in the last couple of days. The code should compile OK, but further
changes are likely.
Glynn Clements <glynn.clements at virgin.net>
