[GRASSLIST:5376] Re: Mac 10.2.3 install problems
edmund edmund at helmug.gr
Sun Jan 26 11:38:50 EST 2003
Thank you for your advice.
But i have added the path /usr/local/grass5
Also i cant find a grass5 startup script to my grass dir.
Thak you again
Kostas Theofilis
On Sunday, January 26, 2003, at 03:14  pm, Thomas Adams wrote:
> Edmund,
> You probably need to put the path where the 'grass5' startup script is
> located in your .tschrc file in your HOME directory. Logout & log back
> in.
> Tom
> edmund wrote:
>> Hi,
>> I am having problems installing the GRASS5 binaries.
>> I follow the instructions at the GRASS site.
>> I have Apple's X11 Server and I have also installed Tcl/Tk 8.4
>> I run the install script.
>> I use the source command
>> I add X11R6/bin to my path.
>> But when i run grass5 i get the message command not found
>> Any help, please?
>> Kostas Theofilis
> Thomas E Adams
> National Weather Service
> Ohio River Forecast Center
> 1901 South State Route 134
> Wilmington, OH 45177
> EMAIL:	thomas.adams at noaa.gov
> VOICE:	937-383-0528
> FAX:	937-383-0033
