[GRASSLIST:624] Re: Can't find r.terraflow in the new snapshot sources.
Glynn Clements glynn.clements at virgin.net
Sat Jul 5 16:28:15 EDT 2003
Antonio wrote:
> I just realized from previous message that it's in the
> src.contribute/DUKE/ directory. But I have another problem to solve.
> When I try to compile it (i compiled grass snapshot in my local user
> dir with the --prefix and --bindir options) I get and error from the
> gmake5 -i command (the output of the log follows below).
> However the problem seems to be (as much as I can understand):
> make: DELEV_SHORT: Command not found
> Could someone help me figure out this problem?
You have to use:
	configure --with-cxx ...
so that configure sets the C++-related make variables.
After running configure, you will also need to do "make pre-compile".
Glynn Clements <glynn.clements at virgin.net>
